How can I load the demo data to my WC 10.1 instance?
  • June 20, 2013
  • 2 replies
  • 1505 views
After installing my WC 10.1 instance (oracle backend), I have a request to add the demo data that comes with the install. How do I add this data to my instance? I tried re-running the installer, but now that I have the existing instance, the database portion of the installer doesn't come up. So is there some ant command that I can use to load the PTC demo data?
This should do the trick.
windchill wt.load.WindchillLoader -LoadOnlyDemo
Thanks to all for the windchill command tips. That did the trick.
