May 22, 2012 8:46 AM UTC
How can the actitvy comments be retrived in a variable. Since i require to send these comments in notification mail in a workflow
How can the actitvy comments be retrived in a variable. Since i require to send these comments in notification mail in a workflow.
Jun 19, 2012 1:45 AM UTC
1. In the Workflow, define a global String variable. example: eeComment.
2. In the Assigned Activity task:
a) define a String variable. example: eeComment. "Copy into" and "Initialize From" the global variable defined in step 1. Only select "Resetable"
b) within the desired "Transitions" use this java code:
wt.workflow.work.WfAssignedActivity activity = (wt.workflow.work.WfAssignedActivity) self.getObject();
wt.workflow.engine.ProcessData actData = activity.getContext();
eeComments = actData.getTaskComments();
c) Click on "Check Syntax"
3. The global String variable, populated in step 2, shall be available in the "Notification Robot". Be sure to select the variable using the "Variable" comand button located on the "Message" tab in the Notification Robot.
I hope this make sense...
Jun 5, 2012 2:38 PM UTC
I would love to know this answer as well. Someone please reply...
dsolat1-VisitorAuthor
Jun 20, 2012 5:21 AM UTC
Thanks a lot...... Have tried it and it works fine......
