May 13, 2016 7:58 PM UTC
How do I get the PTC Windchill printer to work?
How do I get the PTC Windchill printer to work?  I try to print to a file, but I get an error message that says "Printer not activated, error code -30"
May 13, 2016 10:40 PM UTC
Are you using the 'Print' or 'Print To File' option? The 'Print' option expects a hardware printer and will fail with this message if the Windchill printer is selected. The 'Print To File' option should successfully use the Windchill printer.
May 13, 2016 8:02 PM UTC
Additional message that pops up is "Device is not ready".
May 16, 2016 2:38 PM UTC
Thank you Chris.  That did it!
