Jul 2, 2015 2:22 PM UTC
How do I quickly get contents of a CN into a workspace?
I have a Change Notice (CN) with many parts attached to it that require modifications. How do I quickly get these parts into my workspace?
My current process is to print the full list of parts attached to the CN and then sequentially search for each item and individually add it to my workspace. This is very time consuming so is there a way to bring an CN (content of) straight into a workspace?
The way I see it, all the parts are already collected and attached to the CN so this should be a very simple task
Jul 2, 2015 2:26 PM UTC
In Windchill 10.2 if you are in the resulting objects and you select any object, it is under the Actions menu.
scleary1-VisitorAuthor
Jul 2, 2015 2:38 PM UTC
Thanks for the quick response Brian but I am working within Windchill 10.1 and cannot see this option when I navigate to resulting objects.
Do you know if this function added at 10.2 or is it just in a different location?
Your solution is exactly what I was looking for but i cant mark your answer as correct because I am on version 10.1!
Jul 2, 2015 2:42 PM UTC
It is new for 10.2.
18-Opal
Jul 13, 2015 7:05 PM UTC
Until you upgrade, you may be able to do an indexed search by the ECN # and then add from the search results page.  That is what I typically would (I think it works even if you don't have the CN # in the attributes of the object but am not sure on that.
We can both look forward in 10.2 to being able to add directly from the Change Notice!
