How do I re-number CAD files while importing
I have several folders of CAD data I would like to import from different sources, and there are different file with the same part number. To avoid conflicts, I would like to be able to simply re-number all files as I import them. Is there a way to do this?
6-Contributor
May 5, 2014
Hey Mark, did you get an anwer to this question?
I have a dozen folders of Pro/E parts and assemblies files. My boss wants me to simply "import" automatically the files into Windchill so we can browse them. I can not figure out how to do this. I can open one at a time and save them, but don't know how to automate this process. I'm a Com Sci guy running the server and Oracle database, not an Engineer who uses Creo with Windchill. Can you point me to any "importing into Windchill for dummies" documents?
Hi ,
For this you need to do coding using Pro/E API .You can find info in Pro/E customization Guide. There are again two ways to do this Synchronous and asyncro. Choose which ever is fissible for you.
1. Create file (for example mapping.txt) like this:
<?xml version="1.0" encoding="UTF-8"?>
<userSettings>
<mappingRules>
<COPY_AS>
<tag>number</tag>
<value>0000*</value>
<newValue>plm_0000*</newValue>
</COPY_AS>
</mappingRules>
</userSettings>
2. Select this file in import manager (file of the import rules).
3. Import
