Jun 26, 2015 5:36 PM UTC
How do I set revision of imported legacy cad data to the "current revision", say Rev B.2 for example?
I have legacy data from Pro IntraLink that I want to import into Windchil PDM Essentials.
However, most of the legacy data is not at Rev A.1.
So how do I import the legacy data and set at a revision higher than Rev A.1...say Rev B.2 for example.
MikeGwinAnswer
Oct 8, 2015 10:29 AM UTC
There is are options in the preferences to Allow Override on Create New CAD Document also Insert and Revise
TomU
Jun 26, 2015 6:00 PM UTC
You can't do the ".2" part but you can do the "B" part.  Enable the system preference "Allow Override On Create CAD Document"
MikeGwin1-VisitorAuthor
Jun 26, 2015 6:23 PM UTC
That option if already set to yes.
Is this only for documents being "created" in widchill or creo?
Will this option work for importing documents into windchill?
If so, where do you access the revision to change it. In Intralink it was easy to "modify" the file and select the revision. You could jump forward but not backward.
TomU
Jun 26, 2015 6:30 PM UTC
I'm actually not sure.  I think you may actually want to look at your lifecycle template.  If you allow revise from the first state back to the first state again, Windchill will allow you to set the revision of new objects in your workspace (regardless of how they got there) before checking in.
2-Explorer
Oct 7, 2015 7:07 PM UTC
i am having the same issue.  when i import from intralink into windchill, everything is seen as new.  which is fine.  however in order to set my revision, it only allows numbers, not letters.  i cant select A, B, C or anything of that matter.  only numbers.
Oct 7, 2015 7:38 PM UTC
Daniel,
I assume by "only numbers" you mean 1.1, 2.1 or 1.0, 2.0 and not -.0, -.1 or -.2
Then it appears that your Windchill Install was configured to use "Simple Number" Version Shceme as opposed to "Simple Letter" or ASME 14.35 Version Schemes.
Remember it is Version = Revison.Iteration, So Version A.5 is Revision A Iteration 5
Simple # = 1.1, 2.1, 3.1
Simple Letter = A.1, A.2,....
ASME = -.1, A.1, B.1 or -.0, A.0, B.0
See below: (the graphic is not 100% correct)
Windchill also allows you to configure with a starting "Iteration" = 0 instead of 1.
The Out of the Box Install will let you choose the three version schemes but they will all start with Iteration=1.
Mike
2-Explorer
Oct 7, 2015 7:49 PM UTC
thank you.  correct.  our revisions are set to 1.1, 1.2, and so on.. up to 99.  im not worried about a 0 itteration.
i remember the guy who did the original setup for us, asked us if we use number or letter.  we told him numbers.  so i assume he only setup simple#.
We are going through different things to see if we can fix this or not.  im worried our original setup was simple# setup.  Being windchill light, we probably only allowed one way or the other.  not both im assuming?  im trying to get our administrator as much information as i can.
22-Sapphire I
Oct 7, 2015 8:03 PM UTC
It may seem not so important, but believe it that you have to be very precise on terminology.  Different words are used for the same concept and the same words are used for different concepts.
One is key the difference between old Intralink: Set Release Level and Windchill: Revise.
All the terminology is spelled out and comparisons exist.  Need to carefully study each of 1/2 dozen terms in Windchill.
MikeGwin1-VisitorAuthorAnswer
avillanueva
23-Emerald II
Oct 27, 2016 4:27 PM UTC
This has been an issue here. If an item is created and structured but the user fails to set the revision properly, there needs to be a way for the administrator to alter a revision. I can understand the mess that this could cause but it would be invaluable to ensuring that the data is correct.  It can be next to impossible to change what amounts to a single letter in a few fields to another letter.  We are forced to remove and delete to try again. Wasteful.
