May 19, 2015 3:33 PM UTC
How do you disable the "submit the change object now" prompt?
When I attached files to change notices I often get the "submit the change object now?" prompt shown below. Is there a way to turn off this prompt?
BenPerry
BenPerryAnswer
May 19, 2015 5:54 PM UTC
BenPerry
BenPerry15-MoonstoneAnswer
Does this from Mike Lockwood‌‌‌ help you?
Save As on Document - actually work requests
hlogsdon1-VisitorAuthor
May 19, 2015 6:30 PM UTC
Thanks Ben!
ShirishMorkhade
May 28, 2015 1:58 PM UTC
Hi Ben / Hartley,
You can also try this out:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS79510
Shirish
May 28, 2015 2:34 PM UTC
Hello Shirish,
The link is to an internal PTC document and normal users do not have access to it.
Brian
ShirishMorkhade
May 28, 2015 2:36 PM UTC
For Windchill PDMLink 10.x, make the following changes to %WT_HOME%/codebase/netmarkets/javascript/change2/changeWizard.js:
if (submitNowEnabled != null && submitNowEnabled.value == "true") {
                //comment this line out: ChangeManagementSubmitHandler.createSubmitDialog();
                ChangeManagementSubmitHandler.processAndSubmit(true);  // add this line in
