18-Opal
Feb 13, 2018 2:27 AM UTC
how set part path when option 'Auto-connect parts to CAD document' is selected
Hello
I set the storage path of the CAD document to the folder A and checked it in.
At check-in, I chose to automatically connect CAD documents to parts as an option.
CAD documents are stored in folder A
However, auto-connected parts are stored in root.
How do I put the path of the auto-connected part together in the folder where the CAD document is stored?
If you use object initialization rules, you can only assign one path at a time?
I want to store the parts connected to the folder where the CAD documents are stored flexibly.
Thank you.
pmooteriAnswer
Feb 14, 2018 7:28 AM UTC
 With respect to your requirement <<I want to store the parts connected to the folder where the CAD documents are stored flexibly.>>
Can you please try setting below preference?
Name  :  Store New Parts with CAD Documents
Description  :  Specifies the location of newly created parts to be the same as the location of their associated CAD document. When the value is true, newly created parts have the same location as their associated CAD document. The default is false
Pankaj Mooteri
Product Manager, PTC
pmooteri14-AlexandriteAnswer
Pankaj Mooteri
