Jan 30, 2023 1:12 PM UTC
How to add a "Actor" role in team template xml file.
Any inputs on adding a "Actor" role in team template xml file..
tried the below scenerio but failed to add the role.
<!DOCTYPE NmLoader SYSTEM "standard12_0.dtd">
<NmLoader>
<csvTeamTemplateBegin handler="wt.team.LoadTeam.createTeamTemplateBegin">
<csvname>Doc Owner Team</csvname>
<csvdescription>Doc Owner Team</csvdescription>
<csvfolderLocation>/System</csvfolderLocation>
<csvenabled>true</csvenabled>
</csvTeamTemplateBegin>
<csvRoleHolder2 handler="wt.team.LoadTeam.createRoleHolder">
<csvroleToAssign>OWNER</csvroleToAssign>
<csvassignedPrincipal/>
</csvRoleHolder2>
<csvActorHolder2 handler="wt.team.LoadTeam.createActorHolder">
<csvassignedActorRole>Creator</csvassignedActorRole>
</csvActorHolder2>
<csvTeamTemplateEnd handler="wt.team.LoadTeam.createTeamTemplateEnd"/>
</NmLoader>
Fadel
23-Emerald II
Dec 2, 2023 4:19 AM UTC
Hi   ,it is certainly failing with uniqueness exception , this is expected the createTeamTemplate, it is only for creating it does not update existing .
if this not the case , what is the error shown in logs
Buiꓘa
Aug 11, 2025 2:22 PM UTC
it should be:
<csvActorRoleHolder2 handler="wt.team.LoadTeam.createRoleHolder" >
<csvroleToAssign>SUBMITTER</csvroleToAssign>
<csvassignedActorRole>CREATOR</csvassignedActorRole>
</csvActorRoleHolder2>
Aug 11, 2025 3:55 PM UTC
<csvActorRoleHolder2 handler="wt.team.LoadTeam.createActorRoleHolder" >
