Sep 11, 2020 4:33 PM UTC
How to Add a new Role to Multiple Existing Products
I am creating a new Role which I need to add to about 350 existing Products in my Windchill installation.
It appears that my only option is to add that Role to each Product Team one Product at a time.
And, or course, then I will need to add Members to that Role in each Product..., which also appears to be a "one Product at a time" ordeal.
Has anyone discovered a method to add a new Role to MULTIPLE existing Product Teams all at once?
Likewise with adding adding Members to that Role all at once across all the existing Product Teams.
Note: For future Products, I am creating a new Product Template which will contain the new Role..., but adding the new Role to existing Products Teams quickly is a problem.
Thanks in advance.
22-Sapphire I
Sep 13, 2020 9:54 PM UTC
Wow - 350 Product contexts.
In this case, probably best to load from CSV convered to XML via a Windchill shell command.
One example:
https://www.ptc.com/en/support/article/CS20032?&language=en&posno=2&q=add%20role%20to%20products%20loadfromfile&source=search
Likely will want to also add group(s) to the new Role.  Here is a related article:
https://www.ptc.com/en/support/article/CS23194?&language=en&posno=1&q=add%20role%20to%20products%20loadfromfile&source=search
18-Opal
Sep 17, 2020 11:09 PM UTC
This can and should be automated using a script.
What version of Windchill are you on?
What's the name of your new role?
Do you have a map or file that maps the user(s) you want to add to the new role in all 350 Products?
<Product Name>=<username>
Or can you get the user from some other logic such as the users in Role X in Team Y
or
the users in Group Z.
Anything to get them data using logic rather than manually?
David
