6-Contributor
Aug 27, 2024 7:49 PM UTC
How to add 'Add Coversheet' robot in a workflow for Coversheet Wincom Extension?
Version: Windchill 12.0
Use Case: Coversheet Wincom Extension allows users to add cover sheets at the beginning of PDF documents. Coversheets are often required on PDF’s distributed outside of your organization. For example: Sending documents to regulatory agencies, where adding a cover sheet provides the approval audit trail for the PDF’s specific date.
Description:
Hi Team,
Please let us know if you have already worked on Coversheet wincom extension.
We are trying to search how to add 'Add Coversheet' robot in a workflow for Coversheet Wincom Extension?
Our use case: If a Document is processed through a change management, then all the approver and reviewer username should be captured in Coversheet.
jbailey
jbaileyAnswer
18-Opal
Aug 28, 2024 8:08 PM UTC
If you go to the extension manager and the admin guide for coversheet, there are examples for adding/removing cover/trailing sheets via robot.
18-Opal
Aug 28, 2024 6:22 AM UTC
Hi @AK_10995767,
Could you check whether the following article helps your use case
https://windchill-extensions.ptc.com/kb/articles/eCaKoH6kaURMim9F
6-Contributor
Aug 29, 2024 7:02 AM UTC
Hi @TDT , I checked the article you provided, and the article is basically about the Watermark extension. This is helpful for watermark related works, but I am looking for the Coversheet extension related solutions.
Thank you.
jbailey
jbailey18-OpalAnswer
18-Opal
6-Contributor
Aug 29, 2024 7:03 AM UTC
Hi @jbailey , when I clicked on the admin guide icon, I am getting 'Failed to load documentation'. Please share me the admin guide if you have it handy.
jbailey
18-Opal
Aug 29, 2024 12:36 PM UTC
Which build of coversheet do you have installed? Which version of Windchill?
