prerev_kompan
Aug 11, 2026 11:52 AM UTC
How to add attribute from a subtype of Part to a report?
I want to make a report where an attribute (Sales Market) from a Part subtype (Item) is shown.
The attribute is showing the values of referenced Configurable Links with a mapping.
I’ve added the Item type to the Tables, but no luck.
TDTAnswer
18-Opal
Aug 13, 2026 2:14 PM UTC
Hi ​@prerev_kompan,
Alias attributes do not persist values in the DB.
They dynamically display the Alias attribute values when the page is rendered.
I would suggest creating a constant that invokes a custom class containing the same logic as the alias attribute in the Custom Report.
Aug 11, 2026 9:40 PM UTC
It’s not clear what you are asking but this may help
https://www.ptc.com/en/support/article/CS309961
https://www.ptc.com/en/support/article/cs378240
prerev_kompan
Aug 12, 2026 5:50 AM UTC
We have an attribute of type string called “Sales Market” on a subtype of Part called “Item”.
For some reason, this attribute is not visible in reportable item, even if I add the type “Item” to the tables.
joe_morton
Aug 12, 2026 2:28 PM UTC
What version of Windchill are you using?
When you say “Part” do you specifically mean WTPart?
Can you share screenshots?
prerev_kompan
Aug 13, 2026 6:17 AM UTC
We’re using 13.1.2 latest.
We have subtypes of WTPart:
Kompan Part
Sales Market attribute is an Alias attribute collecting information about linked Sales Market objects.
Creating a report with the specific type included:
Using reportable Item:
Sales Market attribute is not on list, other attributes are:
I have discovered some articles stating that Alias attributes can not be used in reports as content/values are not saved in a table but generated on demand.
TDT18-OpalAnswer
18-Opal
Hi ​@prerev_kompan,
joe_morton
Aug 13, 2026 2:55 PM UTC
Ok, that explains it - it’s an alias attribute.
It looks like both the Sales Market object as well as the linking used are both custom. I would think you should be able to update your report to add the link from the WTPart to your Sales Market object, then add the required info directly from the Sales Market object itself. But - we don’t have any custom linking on our system, so I don’t have experience trying to do that.
prerev_kompan
Aug 14, 2026 5:52 AM UTC
Thanks, for all your help!
I’ll try to create a constant and see if I can process the logic.
