Dec 21, 2022 7:17 AM UTC
How to add dropdown attributes on task page and make it required when user select rework/reject
Need to add dropdown in tha task page along with comment and make it required when user select rework or reject option.
Any inputs to achieve this?
HelesicPetr
Dec 21, 2022 7:49 AM UTC
Hi @NP_9998831
It is not easy to set the attribute list in the workflow task.
Usually it is workflow variable with own custom class.
How to achieve it is described here > CS36017
PetrH
Dec 21, 2022 10:38 AM UTC
Yeah,i have seen this article-36017.
But i need a drodown with multi selection on task page.
and it should be required when user select rework/reject option(similar to comment attribute).
HelesicPetr
Dec 21, 2022 10:41 AM UTC
Hi @NP_9998831
The required attribute can be achieved by java check code in a transaction task competition. You can throw an exception with message that the attribute is required if....
Multiselect dropdown combo box can be problem I guess at that place.
PetrH
avillanueva
23-Emerald II
Dec 21, 2022 1:11 PM UTC
This is achievable. I have come close to what you are looking for except I did not use a multiselect drop down. It required a lot of hacking customization. I am looking to move away from this in the future. I have a task where the user picks a team from a drop down list. Simple to add a team variable but I needed a data utility to limit what teams from the system were selectable. This required a custom JSP task template where I can call out the data utility against the variable.  So, you will need the right variable to hold a multiselect result and a data utility to render it.
The easiest way to implement a check based on a routing choice is to put check code in a transition. If the user selects rework and did not populate that attribute with something, throw a WTException with a message to kick the task back to them.
