Jan 26, 2022 3:17 AM UTC
How to add hyperlink in builder
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS17
For example
ColumnConfig expired_qty = getColumn(factory, MaterialBOMDetailBean.EXPIRED_QTY,
messageSource.getMessage(GoldenRB.EXPIRED_QTY_DESCRIPTION), true);
table.addComponent(expired_qty);
ColumnConfig expireDate = getColumn(factory, MaterialBOMDetailBean.EXPIREDATE,
messageSource.getMessage(GoldenRB.EXPIREDATE_DESCRIPTION), true);
table.addComponent(expireDate);
Whether the attribute values ​​in the establishment of two ColumnConfig can be added link
Translated by Simona using Google Translate on 1/26/2022
請問如何在builder 裡面加入 hyperlink
例如
建立兩個 ColumnConfig 裡面的屬性值是否可以加入link
HelesicPetr
Jan 26, 2022 8:40 AM UTC
Hello @HT_9313847 ,
I usually use a DataUtility to render hyperlink.
Create DataUtility class
register the datautility in a service.properties by site.xconf
 <Service context="default" name="com.ptc.core.components.descriptor.DataUtility"
targetFile="codebase/service.properties">
<Option cardinality="duplicate" order="1" overridable="true"
requestor="java.lang.Object"
selector="duHyperLink"
serviceClass="com.custom.HyperLink.HyperLinkDataUtility"/>
</Service>
use the datautility ID(selector) to set in a databuilder
// col is a ColumnConfig ...
col.setDataUtilityId("duHyperLink");
 Simple example of datautility to render hyperlink
public class URLLinkAttribute extends NameNumberDataUtility
public Object getDataValue(String columnID, Object object, ModelContext modelContext) throws WTException
String url = "http:\\www.google.com";
String value = "go TO GOOGLE";
ArrayList<AttributeGuiComponent> urlLinks = new ArrayList();
UrlDisplayComponent urlDisplay = new UrlDisplayComponent(columnID, null, null, null);
urlDisplay.setLink(url);
urlDisplay.setLabel(value);
urlDisplay.setName(value);
urlDisplay.setLabelForTheLink(value);
urlLinks.add(urlDisplay);
return new MultiValuedDisplayComponent(urlLinks);
Hope this can help.
PetrH
