Nov 12, 2024 12:00 PM UTC
How to Analyse publishing job logs for long running job
Version: Windchill 12.1
Use Case: We have some CAD Documents which take a very long time to load in the CADworker, I can see that in the job logs. What I want to do is make a query to a data dump of the job start and end times and the number iof the EPM document, so I can identify objects which take along time to load.
Description:
We have some CAD Documents which take a very long time to load in the CADworker, I can see that in the job logs. What I want to do is make a query to a data dump of the job start and end times and the number iof the EPM document, so I can identify objects which take along time to load. I can see there is a db table for publishing stats, but its only got the job start and end date, not the time, so where are the job logs stored?
Nov 13, 2024 11:29 AM UTC
Windchill Performance Advisor can bake that data for you and provide XML file. This is your OOTB starting point.
I think you can easily process the XML to get the further data quality you are looking for.
Cheers
Hari
