Jan 9, 2026 4:33 AM UTC
How to assign custom lifecycle to Mathcad prime file while check-in is done from MathCAD
when Mathcad prime 9.0 file is checked-in in Windchill 12.0.2 it defaults to Basic LC.
What steps needs to be taken in order it pick's up the custom LC.
Any reference would be of gr8 hlp.
18-Opal
Jan 9, 2026 10:24 AM UTC
Hi @DKWc,
This can be achieved by assigning an OIR to the Mathcad object.
If only one object is involved, the Reassign Lifecycle Template action may be used to assign a custom lifecycle.
DKWc15-MoonstoneAuthor
Jan 9, 2026 10:54 AM UTC
Thanks for reply.
When checkin Mathcad from the interface, it defaults to Dynamic Document. We already have Arbotext intergration.
Thought a approach for creating a CADdocument template, however in case we cannot choose the .mctx (mathcad template) file.
how can we default to a sub-type. Frist place where Mathcad should be dynamic/cad?
18-Opal
Jan 13, 2026 7:00 AM UTC
Hi @DKWc,
Could you please check whether any OIR is configured for the dynamic document?
The lifecycle configuration can be controlled through OIR by using a boolean or case branch based on the authoring application.
Please refer to the article below for more details.
https://www.ptc.com/en/support/article/CS396081?source=search
