Oct 13, 2016 12:11 PM UTC
How to assign handler to cad template load file
Hello!
I'm wondering if it's possible to assign a handler to load files that doesn't seem to have one.
Exemple ..Windchill/loadFiles/creo/creoTemplates.xml
That file contain below text:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE OrganizationConfig SYSTEM "standardX24.dtd">
<OrganizationConfig>
    <loadXMLFile>cad_templates/creo/ptc_wm_inlbs_asm_esr_Template.xml</loadXMLFile>
    <loadXMLFile>cad_templates/creo/creo_elementspro5_mmns_design_template.xml</loadXMLFile>
    <loadXMLFile>cad_templates/creo/ptc_wm_mmns_part_solid_template.xml</loadXMLFile>
    <loadXMLFile>cad_templates/creo/ptc_wm_mmns_csa_template.xml</loadXMLFile>
    <loadXMLFile>cad_templates/creo/ptc_wm_mmns_asm_module_template.xml</loadXMLFile>
</OrganizationConfig>
No handler in sight.
Reason is that I would like to add deletion before the CAD document is loaded to the system.
Current Windchill behaviour is to throw an exception:wt.pom.UniquenessException.
If I can delete before I can load then there won't be any manual hacks required in the GUI
Thanks for any assistance!
/Peter
