8-Gravel
Oct 21, 2024 5:25 AM UTC
How to auto save Jconsole's log? (like Heap Memory Usage)
Hello
I want to save the Jconsole's log because windchill stopped sometimes.
Our PLM Enginner says 'this problem is about to Heap Memory size. Out of memory'
So, I want to monitor heap memory usage with Jconsole.
But I can't find the Jconsole's Log Auto Save function.
How to Auto Save the Heap Memory Usage log?
avillanueva
23-Emerald II
Oct 24, 2024 12:33 PM UTC
I would not spend your time right now monitoring those logs if you know you are having memory issues. I recommend tuning your system to prevent it from happening in the first place:
https://www.ptc.com/en/support/article/CS153338?source=search
Assuming you have enough resources dedicated to the system, you need to make some parameter changes and allocations. The WCA can make recommendations.
Emeritus
Oct 24, 2024 7:47 AM UTC
Hi @HK_10285495,
Thank you for your question.
Vivek N
Community Moderation Team.
avillanueva
23-Emerald II
