Jan 30, 2015 4:49 PM UTC
How to avoid publishing for a particular context (Product in our case)
We are on Windchill 10 M040. We are currently mass loading CAD Files (.SLDPRT) into a particular context. We do not want to publish these files for now. These files follow the same LC as any other EPM Document. Is there a way to prevent publishing only for this context, as it puts a huge backlog on the WVS jobs.
Rajesh Balasundaram
    Jan 30, 2015 8:51 PM UTC
    Rajesh,
    You can write custom filter method to check if document is for particulate context. see below links for more details.
    http://www.ptc.com/cs/help/windchill_hc/wc100_hc/index.jspx?id=WCCG_BusLogicCust_WCVisualization_CustPublish&action=show
    https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS98475&posno=1&q=publish%20filter&source=search
    Hope it helps !!!
    Shreyas
