3-Newcomer
Jun 23, 2026 9:31 AM UTC
How to configuration the documnet with manual numbering with the postfix
We have a requirement to configure WTDocument numbering with manual numbering and an automatically appended postfix, without using any additional attributes.
Example:
Number Format: XXXX_YY
Where:
  • XXXX = User-entered manual number
  • YY = System-generated postfix based on the document subtype
Example:
  • D1 → DOC001_CR
  • D2 → DOC002_CR
  • D3 → DOC003_CI
  • D4 → DOC004_CI
Could you please confirm whether this requirement can be achieved through OIR configuration alone, or if a customization (such as a Form Processor, Number Generator, or Event Listener) is required?
Additionally, is there any standard Windchill approach to append a fixed postfix to a manually entered number without introducing additional attributes?
TDTAnswer
18-Opal
Jun 23, 2026 10:12 AM UTC
Hi ​@Mruthyunjaya,
It requires customization.
TDT18-OpalAnswer
18-Opal
Hi ​@Mruthyunjaya,
Jun 23, 2026 10:01 PM UTC
This can easily be done OOTB and requires no customization.
All you have to do is take the example PTC provides.
<AttributeValues objType="wt.doc.WTDocument">
<!-- set the number to a generated number -->
<AttrValue id="number"
algorithm="com.ptc.windchill.enterprise.revisionControlled.server.impl.NumberGenerator">
<Arg>REF-</Arg>
<Arg>{GEN:wt.enterprise.SequenceGenerator:WTDOCUMENTID_seq:10:0}</Arg>
</AttrValue>
</AttributeValues>
and move it lower.
<Arg>-REF</Arg>
</AttrValue>
</AttributeValues>
Jun 23, 2026 10:05 PM UTC
Ahhhn apologies I missed the user entered number part.
