Nov 27, 2025 10:55 AM UTC
How to configure a worker with basic auth in a windchill sso configured environment.
avillanueva
23-Emerald II
Dec 8, 2025 5:10 PM UTC
Trusted host is deprecated yes but a replacement has not been provided. Ok to use that for now.  You can remove the password from the auth.properties and the CAD worker should be trusted.
Dec 1, 2025 12:47 PM UTC
https://www.ptc.com/en/support/article/CS372426?source=search
It seems the trusted host is deprecated. Using windchill 12.1
How doe we register the url in server management and use basic authentication instead of SSO?
jbailey
18-Opal
Dec 1, 2025 12:57 PM UTC
Depending on which version of Windchill you are on, it will still work. I can confirm it works on 13.0.2.x. It uses an already open URL for basic auth that enforces access via the trustedhosts configuration. Is there a reason you need basic auth instead of the $user variable method? Obviously with the Client Credential Grant method you will need to configure Windchill for OAuth.
