Jul 10, 2024 8:55 AM UTC
How to Create a STEP File Using CADWorker
I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020-CPS16
Is it possible to create a STEP file using CADWorker?
Additionally, when converting, is it possible to retrieve specific attributes from the CAD data and use the retrieved values as the file name?
rleirAnswer
Jul 10, 2024 9:09 AM UTC
This article seems to answer you
https://www.ptc.com/en/support/article/CS81396
rleir17-PeridotAnswer
Jul 12, 2024 3:49 AM UTC
Thanks for letting me know.
Jul 10, 2024 12:29 PM UTC
An after loader hook can be created to change the file name.  These articles illustrate a rename examples.
https://www.ptc.com/en/support/article/CS252900
https://www.ptc.com/en/support/article/CS349681
If this is Creo publishing, Genius Tools Model Processor Worker (MP Worker) is an alternative that doesn't require custom class files...
MP Worker integrates into Creo CAD Workers to produce anything Creo can export.  Following an instruction set called an "Actions List", MP Worker can analyze or manipulate the model to produce CSV report files, PDFs, sheet metal flat state DXFs, neutral formats, etc.  File names can be altered as desired, leveraging model parameters and regular expression replacement, before upload as Representation additional files.  MP Worker can manipulate the Creo model, but cannot save or upload Creo model changes as that is prohibited by publishing.
https://www.felcosolutions.com/geniustoolsmodelprocessor
https://www.inneo.co.uk/en/product-development/inneo-in-house-products/genius-tools/genius-tools-model-processor.html
Jul 12, 2024 3:50 AM UTC
Thanks for sharing the details.
