Aug 11, 2015 11:25 PM UTC
How to Create a Where Used Report with Query Builder
Hello.
Would like to output a Report showing the Used By (Where Used) of a component or assembly.
We can see Where Used on the Information Page of the CAD Part or Assembly.
We can see and collect them on the affected objects of a Change Request.
In neither location can you export the list to a CVS/XLS File, etc...
The Use Case: the ERP Person wants to compare the Windchill System to the ERP System to compare the systems to see how closely there align.  (Systems not current integrated and Manual Entry Process in Place for MRP)
For Example
SmallAsmX is Used By 261 Parent Assemblies...
We would like to do a Query Build Report, and Export the Report out, then we can compare the list to the list in the MRP System which can export out.
Easier to compare when the two list are side by side.
If you have made a Where Used Report, would you export and attach?
2-Explorer
Aug 12, 2015 4:02 AM UTC
Please have a look at CS103435 and CS189253
Binesh Kumar
Barry Wehmiller
