Apr 15, 2015 8:29 PM UTC
How to create load file to import globale attribute
Hello
I would like to know all the step to create load file (xml) to import global Attributes via LoadfromFile command.
thanks
PrabhashAnswer
Apr 16, 2015 1:47 PM UTC
I think you will get an idea from this article...https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS30168#sample
Prabhash1-VisitorAnswer
2-Explorer
Apr 16, 2015 11:36 PM UTC
We created an .xml load file to contain all of our IBAs with Windchill V9.1 and it translated into Global Attributes in Windchill 10.2. We were able to use the same load file with 10.2 as we did with 9.1. Here is an example of the format:
<?xml version="1.0"?><!DOCTYPE NmLoader SYSTEM "standardX10.dtd">
<NmLoader>
<csvAttrDefinizer handler="wt.iba.definition.DefinitionLoaderWithCache.createAttrDefinizer">
<csvname>activeInd</csvname>
<csvhierarchyDisplayName>Active</csvhierarchyDisplayName>
<csvorganizerPaths>Our IBA Organizer</csvorganizerPaths>
<csvdefinitionPaths/>
<csvdisplay_name>Active</csvdisplay_name>
<csvdescription>Active</csvdescription>
<csvdata_type>Boolean</csvdata_type>
<csvQoMName/>
<csvnameValuePairs/>
<csvlogicalIdentifier>activeInd</csvlogicalIdentifier>
</csvAttrDefinizer>
<csvname>actualAvailabilityDate</csvname>
<csvhierarchyDisplayName>Actual Availability Date</csvhierarchyDisplayName>
<csvdisplay_name>Actual Availability Date</csvdisplay_name>
<csvdescription>Actual Availability Date</csvdescription>
<csvdata_type>timestamp</csvdata_type>
<csvQoMName/>
<csvlogicalIdentifier>actualAvailabilityDate</csvlogicalIdentifier>
</csvAttrDefinizer>
</NmLoader>
