3-Newcomer
Apr 27, 2026 11:20 AM UTC
How to create the Project which in the Dev environment should be in Test Environment
I am using Windchill PDMLink Release 13.0 and Datecode with CPS 13.0.0.2 Hello , Could you please let me know how can I create the Project which is available in the DEV environment with some folder and objects should be same create in the another environment ? Or please share any article related to the same.
6-Contributor
May 18, 2026 1:54 PM UTC
Hello All,
I have found an solution.
Firstly need to export the folder content using Export from file.
Next, need to create the Project and along with Folder XML name and load it using Load from file
I have tested with bulk projects and got created and folders are also created successfully.
Thanks to all your inputs.
MarcoTosin
Apr 27, 2026 2:51 PM UTC
Your request isn't entirely clear, but if I understand correctly, you've created a project in the DEV system with a folder structure and objects inside it.
You can replicate this structure by saving the project as a template, exporting the template from DEV, and importing it into another system.
The objects contained in the project's folders, however, must also be created separately in the new system.
Marco
6-Contributor
Apr 27, 2026 3:13 PM UTC
Absolutely right !, what you had understand my post. Should I use Save as Template or Export as Template ?
avillanueva
23-Emerald II
Apr 27, 2026 3:19 PM UTC
If you are referring to project templates, you can save your project as a template then export that template to a output file. From there, I believe the process is you can import that file as a project template in your Test environment. You need to make sure any dependencies match from environment to environment.
18-Opal
Apr 28, 2026 7:56 AM UTC
Hi ​@DA_11608117,
As ​@Marco Tosin , ​@avillanueva mentioned, you can use project templates to maintain the folder structure and team members.
If you require the same data, you will need to recreate it or use Import/Export Management, or create demo data through load files.
6-Contributor
Apr 28, 2026 3:35 PM UTC
you mean to use Load from file or just import the exported zip file from (Source System )
18-Opal
May 5, 2026 6:19 AM UTC
Hi ​@DA_10909715,
Could you please clarify your requirement?
Do you need to replicate the same data, or is it sufficient to maintain the same project folder structure, team members, and ACLs?
Catalina
Community Manager
May 14, 2026 1:54 PM UTC
Hi ​@DA_11608117 ​@DA_10909715
I wanted to see if you got the help you needed on your post:
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Best regards,
Catalina
PTC Community Moderator
Catalina | PTC Community Manager
6-Contributor
Hello All,
