Dec 10, 2015 12:44 PM UTC
How to create Type, Attribute and relationship in PDMLink 9.0?
How to create HardType, HardAttribute in Windchill 9.0? And how to map created hard-attribute to newly created hard-type?
Also how do I create relationship b/w two types in Windchill? It there any Plugin for it or I need to write  JAVA class for it.
Please help..
Thanks - Vasant
Dec 10, 2015 2:35 PM UTC
Why are you using Windchill 9.0, it is out-of-date and unsupported by PTC? If you are doing a new install, use 10.2 as it is the latest and you avoid the upgrade problems.
Also, 10.x implemented a new architecture that makes adding custom attributes easier.
Feb 19, 2016 10:58 PM UTC
You really shouldn't try to mess around with the Hard attributes, they are an utter pain to work with.
Try to see if Global attributes will work for you, they are far more flexible.
23-Emerald II
Feb 27, 2016 12:23 AM UTC
Vasant Padhiyar‌ - were you able to work past this issue?
