Nov 14, 2013 11:59 AM UTC
How to customize notification email subject to include more information like Change request number , Process Name
I am sending notification through activity's "send notification" option and not through “notify by email robot”
I have modified <WT_HOME>\codebase\templates\workNotification\GeneralSubject_<Locale>.html
files by adding below scripts
<SCRIPT>
beginSubject
</SCRIPT>
Subject of Notification:
<SCRIPT LANGUAGE=Windchill>
getPrimaryBusinessObjectName
</SCRIPT>
endSubject
</SCRIPT>
But the changes are not reflecting and getting only the activity name in the subject of my email.
Do I need to set any property for this? Or any configuration in workflow activity?.
jpoilvetAnswer
Feb 18, 2015 10:35 AM UTC
Hello Naveen,
To modify the subject of the notification email, there is no out-of-the-box solution because it is hardcoded to always be the Activity Name defined in the workflow.
One workaround would be to modify the activity name with some java code in your workflow.
I would suggest to follow the resolution from article CS151717 (https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS151717).
Kind Regards,
Jerome Poilvet - Technical Support Engineer
PTC Technical Support - 00 800 PTC4HELP (00 800 78244357) – http://support.ptc.com
jpoilvet14-AlexandriteAnswer
Hello Naveen,
Kind Regards,
