Apr 11, 2017 2:20 PM UTC
How to define an access policy to a role so that he can have only access to Print and View WTObject?
I have to Create a role and set accesses policy as they can only have access to view and take print of WTObject (WTDocument, EPMDocument)
2-Explorer
Apr 12, 2017 1:11 PM UTC
If you haven't changed out of the box ACLs and is using one of the out of the box product templates, you can use guest role for this.
kkumar-71-VisitorAuthor
Apr 13, 2017 6:36 AM UTC
HI, Binesh,  Thanks for Response.
I have Check the Guest Role, For Both product and Project Context User will able to Download the Document with Action Download As Primary File. So how disable that Download as Primary Action.
For both EPMDocument and WTDocument Access Policy for Guest role is Read Only (Checked).
Please see the attachment below.
Apr 14, 2017 6:21 AM UTC
Issue Resolved
Create New profile for View and Print and Assign that Profile to the Respective Participants. or  Create Profile for Guest Role, Disable Download As Primary Action.
Apr 26, 2017 2:52 PM UTC
Create New profile for View and Print and Assign that Profile to the Respective Participants. or  Create Profile for Guest Role, Disable Download As Primary Action, it Not able to Open in Creo View (Error Occurred) and also the Same Action Not working in Project Context.
