3-Newcomer
Apr 27, 2026 5:03 AM UTC
How to delete a new version of 3D and drawing in winchill?
I accidentally created a new version of a part's model and drawings. I want to delete the files for this new part, but the operation keeps failing. What is the cause, and how can I resolve this?
avillanueva
23-Emerald II
Apr 27, 2026 3:23 PM UTC
Please post the error message you are seeing. If could be that its in a user’s workspace. Might need admin rights to remove. versions should be able to be deleted and returned to previous one.
Apr 28, 2026 5:37 PM UTC
You need to work backwards through the structure to delete them. Assuming the part/assembly has not been used in another assembly, delete the drawing first. Then delete the assembly and finally the parts.
