Dec 29, 2022 7:39 AM UTC
How to delete existing OIR from loadFrom File
Need to delete the existing specific oir from the system using load from file instead doing it manually from UI.
Any Inputs to achieve this?
HelesicPetr
Jan 4, 2023 1:17 PM UTC
Hi @NP_9998831
Unfortunately if the Windchill\loadFiles\csvmapfile.txt does not contains the OIR delete definition you can not use load from file to delete OIR rule because function does not exists.
PetrH
Jan 4, 2023 4:24 PM UTC
Maybe it's possible to load new xml into the existing OIR, an empty xml file which does nothing
Jan 20, 2023 5:16 PM UTC
Hello
@HelesicPetr is right, PTC  doesn't provide tool to delete OIR. Personnally, i delete them manually because i don't have so much.
I had similar situation with Task Form Templates and too much manual delete to do. So, i created a Java program to delete them from a list in a text file. I think it is feasible for OIR,  Java class of OIR is wt.rule.TypeBasedRule.
Pascal
Jan 30, 2023 1:14 PM UTC
Thanks for the reply,
Can you please share the program for task form templates..
