Jun 4, 2019 8:14 PM UTC
How to disable ODATA return limit of 25 entries
Hi All,
How would I disable the limit of 25 entries for ODATA REST endpoints for windchill?
ex. <server>/Windchill/servlet/odata/v3/DocMgmt/Documents ---- only returns 25 entries
Patrick
Jun 6, 2019 12:09 PM UTC
@pa2t  I am not sure what you mean by "disable ODATA return limit of 25 entries".
Assuming what you want is increasing the limit of entities return, try below:
Specify header
Prefer : odata.maxpagesize=<no of entities up to 200>
For example: adding below the header will increase the entities return count from 25 to 150
Prefer : odata.maxpagesize=150
Currently, the maximum root entities retrievable is 200.
Jan 30, 2020 10:41 PM UTC
Hi.
@amarsingh , is there a way to configure this on the OData connector itself (that is on TWX side)?
Thanks!
Feb 4, 2020 11:08 AM UTC
I know a way by adding a custom header. There is an post already about Thingworx swagger connector but the same should be applicable for Thingworx OData Connector.
Link to the article: https://community.ptc.com/t5/ThingWorx-Developers/Custom-headers-for-swagger-connector/td-p/538759
Feb 4, 2020 4:02 PM UTC
FYI, there is also a Windchill knowledge article that touches on this:
https://www.ptc.com/en/support/article?n=CS294238
Feb 4, 2020 7:33 PM UTC
Yes, this is the original article that explains that REST request headers should be modified to include the parameter:
"Prefer" + "odata.maxpagesize=100"
But it does not explain how to perform that at OData connector level.
Feb 4, 2020 9:12 PM UTC
I have created a short document on this here https://community.ptc.com/t5/ThingWorx-Developers/Adding-a-Custom-header-in-Thingworx-Connector/td-p/647507. Let me know if you still face difficulties
