Oct 6, 2016 6:04 AM UTC
How to do to run a validator for CAD objects for the SaveAs command and Rename
Hi
I need to
validate the parameter "number" in Windchill for CAD objects and parts when are performed SaveAs and Rename command.
Created validator class in which redefined the functions - validateSelectedAction(), validateSelectedMultiSelectAction() and validateFormSubmission()
What is the "action" I need to use to register the validator class?
What do I need to specify the "selector" to the calling function validateSelectedAction(), validateSelectedMultiSelectAction() and validateFormSubmission()
I tried to do as shown below, but are not called validators.
<Service context="default" name="com.ptc.core.ui.validation.UIComponentValidator" targetFile="codebase/service.properties">
        <Option requestor="null" serviceClass="ext.ntck.validators.NTCKValidator" selector="WFSAVEAS" />
        <Option requestor="null" serviceClass="ext.ntck.validators.NTCKValidator" selector="MULTIRENAME" />
</Service>
Thanks.
Apr 10, 2019 2:12 PM UTC
Did you find any work around for this. If yes please share, i am also stuck in same kind of problem.
miles_cao
Jun 6, 2022 5:15 AM UTC
This seems to be controlled by an unsupported API com.ptc.windchill.uwgm.cadx.saveas.SaveAsActionDelegate
INFO : wt.log4j.jmx.LoggerRepositoryMonitor.levelChanged - Logger=com.ptc.windchill.uwgm.cadx.saveas.SaveAsActionDelegate, OldLevel=ERROR, NewLevel=ALL
TRACE : com.ptc.windchill.uwgm.cadx.saveas.SaveAsActionDelegate wcadmin - SaveAsActionDelegate.valid :: context object is - wt.part.WTPart:780158
TRACE : com.ptc.windchill.uwgm.cadx.saveas.SaveAsActionDelegate wcadmin - SaveAsActionDelegate.valid :: object is valid - returning TRUE
TRACE : com.ptc.windchill.uwgm.cadx.saveas.SaveAsActionDelegate wcadmin - SaveAsActionDelegate.enableable :: Returning TRUE
TRACE : com.ptc.windchill.uwgm.cadx.saveas.SaveAsActionDelegate wcadmin - SaveAsActionDelegate.valid :: context object is - wt.epm.EPMDocument:678138
TRACE : com.ptc.windchill.uwgm.cadx.saveas.SaveAsActionDelegate wcadmin - SaveAsActionDelegate.valid :: copyAllowed is true
INFO : wt.log4j.jmx.LoggerRepositoryMonitor.levelChanged - Logger=com.ptc.windchill.uwgm.cadx.saveas.SaveAsActionDelegate, OldLevel=ALL, NewLevel=ERROR
