Feb 10, 2014 9:38 PM UTC
How to document or baseline PartsLink classification schema
We are building our classification schema using Counterpart (10.1 M030), to be loaded into PartsLink.
How are other users documenting or baselining their schema? Also, how are you sharing the schema for others to review prior to release?
Any help on what worked/did not work would be appreciated.
Jan 5, 2015 3:46 PM UTC
In 10.1, one possible way is to export schema in csv format. There is a command line propery to do so (In 10.2, you could use UI to export it in CSV). Once you have that CSV, you could review offline with others and manage it as controlled document in projectlink kind of repositaty to keep track of changes and compare.
Other ideas and enhancements suggestions are welcome
