Jun 3, 2015 2:11 PM UTC
How to download all visualizations
Hi Community,
in one of our current projects we need to download all visualizations available in Windchill. As we noticed visualizations in windchill are not connected to the filevault via database tables.
How can we get to all the visualizations available in windchill? They may be available in the file vaults, since there are a lot of files in file vaults, not available in epm document file tables, but where can i get the real file names?
Regards
Stefan
satre-2Answer
Jun 9, 2015 10:14 AM UTC
Below is sample SQL will give you the links between tables and actual file location in local drive
select ap.fileName,fvm.path ,ad.filesize ,
fvm.path || '\' || to_char(fvi.uniquesequencenumber,'0000000000000x') as VaultName
from
ApplicationData ap,HolderToContent hc,DerivedImage de,FvItem fvi ,FvFolder fvf , FvMount fvm
where
hc.idA3B5=ap.idA2A2 and de.idA2A2=hc.idA3A5
and ap.idA3A5=fvi.idA2A2 and fvi.idA3A4=fvf.idA2A2
AND  fvm.idA3A5=fvf.idA2A2;
Hope it helps !!
Shreyas
Jun 4, 2015 9:42 PM UTC
You could write a DB query to get the filevault location of all the visualizations. The DB table that stores information about visualizations is the DerivedImage table.
srohde1-VisitorAuthor
Jun 9, 2015 8:19 AM UTC
Hey Chris,
thank you for your answer. Do you know how the DerivedImage table is conncted to the fvitem table? Or how do i find out the where the derived image is stored in the file system?
Jun 9, 2015 8:48 AM UTC
You can write custom java class file to download representation to Local disk
Below are the few API’s which may help you to write custom java class / utility.
To Get representation for EPMDocument/Drawing
VisualizationHelper helper = new VisualizationHelper();
QueryResult qr = helper.getRepresentations(epmm);
Write custom method to file correct and default representation
Representation representation = getLatestRepresentation(qr);
Use below code to download representation/PDF to folder Local Drive.
  ContentHolder holder = ContentHelper.service.getContents(representation);
  Vector contents = ContentHelper.getContentListAll(holder);
  ApplicationData data = null;
  for (int i = 0; i < contents.size(); i++) {
  if (contents.get(i) instanceof ApplicationData) {
  data = (ApplicationData) contents.get(i);
  if (data != null && data.getFileName().endsWith(".pdf")) {
  iDownloadDocuments++;
  String dLFile = data.getFileName();
  int index = dLFile.lastIndexOf("_");
  String dLFile_trim = dLFile.substring(0,index);
  //String out_path_dir = dlLoc + "\\" +dLFile;
  String path = dlLoc + "\\" + dLFile_trim+"_"
  + epmm.getVersionIdentifier().getValue()
  + epmm.getIterationIdentifier().getValue()
  + ".pdf";
  ContentServerHelper.service.writeContentStream(
  data, path.toUpperCase());
  writelog(epmm.getCADName() + " : PDF downloaded");
  System.out.println("Download Executed.\n");
  System.out.println("File name is"+data.getFileName());
  break;
Hope this helps !!!
Shreyas
Jun 9, 2015 11:41 AM UTC
This was what i searched for , works like a charm. Thank you very much sir . Your help was greatly appreciated.
