There are a few things you need to do in order to modify folder or object level permissions (which is known as "Ad-Hoc" permissions).
- Go to your Site>Utilities page and open Preference Management.
- Find the preference called "Access Permission Configuration (PDM)" (this is for Products and Libraries)
- Edit this preference to change the value for any specific action to "Update".
- Save the preference.
Now once that is done, you can update the ad-hoc permissions on a folder (and all objects and sub-folders within it, if desired) or a specific object with the following rules (assuming you have "Update" set for the action):
- If an ACL is configured to GRANT an action on the folder/object (grayed out checked box), you cannot apply an ad-hoc DENY (un-check).
- If an ACL is configured to DENY an action on the folder/object (grayed out empty box), you cannot apply an ad-hoc GRANT (check).
- You can apply an ad-hoc GRANT on a folder/object only if neither a grant nor a deny ACL exists for that action (white empty check box).
- You can only ad-hoc DENY access to something that had been previously ad-hoc GRANT-ed (white checked box). This is more accurately stated as "removing the GRANT", rather than actually "applying a DENY".
I'd be happy to discuss your overall access configuration in greater detail, if desired - feel free to send me an e-mail.
