11-Garnet
Dec 5, 2017 6:36 PM UTC
How to edit Young's modulus in Material file
I have a material file stored in our Library that I cannot seem to find or edit. I need to change the Young's modulus value, do you know a way to do this?
tjeromeAnswer
11-Garnet
Dec 8, 2017 4:08 PM UTC
Hey lhoogeveen
thanks for this. We had to first save it as a .mtl file, then edit the MAT file with converted units and move it to the appropriate directory in our library. But this solution did work! Thank you for this.
What is the difference between a MAT and MTL file? Just comparing them in notepad it woudl appear .mtl files are written in some kind of script format.
Dec 5, 2017 9:24 PM UTC
If you have the material assigned to a part, you can export the *.mtl file to disk and then edit it.
Dec 5, 2017 9:31 PM UTC
You can find you where your Creo materials are located by looking at the pro_material_dir config option in Creo.  Once you find the material in Creo, try right clicking on the material and then clicking Properties to edit the Modulus.
If you want to incorporate this change into your company's material library: Once you have you changes complete, then Save a Copy to a local folder location or to your Windchill workspace. Then you will need to put the updated material file in the pro_material_dir location.
  • Windows folder for your pro_material_dir location, simply replace the existing file in the pro_material_dir location. Create a backup of the old material if desired.
  • Windchill folder for your pro_material_dir location, you may need to check out the existing material to a workspace before doing Save a Copy to your workspace. Updating secondary CAD files stored in Windchill is a pain...
tjerome11-GarnetAuthorAnswer
11-Garnet
Hey lhoogeveen
Dec 8, 2017 4:47 PM UTC
.MAT is the previous format for materials and .MTL is the new format for materials. Both still work in Creo. I'm not sure if there's specific functionality improvements in .MTL versus .MAT (perhaps for FEA properties). If you created a new material in Creo today, it will default to .MTL.
