11-Garnet
Jun 6, 2024 3:19 PM UTC
How to Enable WVS Publishing on WTPart
I am using Windchill PDMLink Release 11.2 and Datecode with CPS 11.2.0.0
Enable WVS Publishing on WTPart:
How to publish WTPart and its Attributes data to PDF?
ScottMorris
Jun 10, 2024 6:31 PM UTC
Check out this PTC Support article: https://www.ptc.com/en/support/article/CS36657
This only works for Word and Excel and is accessed via Quick Parts in the apps
ScottMorris
Jun 6, 2024 5:00 PM UTC
Does the wt.part in question have any content files associated with it, like CAD or DOC?
smorla11-GarnetAuthor
11-Garnet
Jun 7, 2024 3:55 AM UTC
Yes, WTPart has word Document and a Thumbnail image associated. We need to publish to pdf with WTPart Attribute information along with Thumbnail image on pdf page.
Note: WTPart having lot of attribute required information. (no CAD/Part association in this case) only to extract Part information to PDF.
ScottMorris
Jun 10, 2024 3:09 PM UTC
Couple of ideas come to mind
  • With Windchill Desktop Integration in Office, you could map these attributes into the Word document/template to have them published with the document
  • PTC has a Coversheet option for document publishing in Windchill, but it's a bit involved to setup
  • There is a Windchill Extension for Coversheets too, but would be an additional cost to implement
