Jun 19, 2012 9:40 AM UTC
How to execute an I*E task from Java code.
Hi all,
Has anybody got a small example of executing an I*E task (in folder <windhcill_home>/tasks/...) from a Java code. ? I use the following code which throws error.
String taskPath = "D:/ptc/Windchill_9.1/Windchill/tasks/searchOrg.xml";
WTProperties wtproperties = WTProperties.getLocalProperties();
String instance = wtproperties.getProperty("wt.federation.ie.VMName");
System.out.println("instance = " +instance);
Task task = new Task(taskPath);
task.addParam("instance", instance);
task.invoke();
The error I get is
java.lang.ClassNotFoundException: com.ptc.windchill.keystore.WTKeyStore
at java.net.URLClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at com.infoengine.au.IEProperties.preload(IEProperties.java:245)
at com.infoengine.au.IEProperties.<init>(IEProperties.java:269)
at com.infoengine.au.NamingService.getIEProperties(NamingService.java:1398)
at com.infoengine.SAK.TaskCompiler.<init>(TaskCompiler.java:119)
at com.infoengine.SAK.Task.compile(Task.java:1827)
at com.infoengine.SAK.Task.invoke(Task.java:1736)
at ewb.test.TestClass.main(TestClass.java:91)
Exception in thread "main" java.lang.NullPointerException
at com.infoengine.procunit.adapter.Adapter.createConnection(Adapter.java:912)
at com.infoengine.procunit.adapter.Adapter.<init>(Adapter.java:160)
at com.infoengine.SAK.ObjectWebject.invoke(ObjectWebject.java:143)
at com.infoengine.compiledTasks.file.D$3a.ptc.Windchill_9$2e1.Windchill.tasks.ext.flex.searchorg$2exml.invoke(searchorg$2exml.java:73)
at com.infoengine.SAK.Task.invoke(Task.java:1783)
LoriSoodAnswer
23-Emerald II
Jan 23, 2015 8:51 PM UTC
Rama,
Are you getting the same error as above?
I think this article goes along with what Dave mentioned in letting the I*E server/Adapter from the method server handle the task processing:
http://support.ptc.com/appserver/cs/view/solution.jsp?n=CS146753
Jul 3, 2012 7:25 PM UTC
Try this.
WTProperties props = WTProperties.getLocalProperties();
Task myTask = new Task("ext/myTask.xml", props.getProperty("wt.federation.ie.VMName"));
myTask.setUsername(user.getName());
myTask.addParam("param1", "param1value");
emailTask.invoke();
It looks like your task is being called though from the stack trace above, so I'm guessing its a problem with the content of your task file itself.
Jul 12, 2012 9:16 PM UTC
Why did you do this?
I always use the IE servlet via the method server.
Are you running the separate Info*Engine server?
Jul 13, 2012 5:01 AM UTC
Thanks David.
Do you have any code samples of calling thru IE servlet ?
And my I*E server runs within the method servers. Do you know of any configurations to have it run externally.
Jan 19, 2015 2:47 PM UTC
David,
Did you get any help on this topic. Am trying to do the same. Please let me know if you hve a running snippet for this.
RK
