Nov 11, 2013 4:01 PM UTC
How to export subtypes as loadfiles?
Hello!
Does anyone know if it's possible to export a subtype of WTDocument as a separate loadfile(s)?
The below loadfile will export the CADDocument type:
<?xml version="1.0"?>
<!DOCTYPE NmLoader SYSTEM "standardX20.dtd">
<NmLoader>
<csvExportDefinition handler="com.ptc.core.lwc.server.TypeDefinitionExporter.beginExportDefinition">
<csvtoLocation>/ptc/Windchill/temp/export/types/CAD_Document</csvtoLocation>
<csvtoFileName>CAD_Document.xml</csvtoFileName>
<csvexportDefClass>com.ptc.core.lwc.server.LWCTypeDefinition</csvexportDefClass>
<csvexportNames>com.volvo.DefaultEPMDocument</csvexportNames>
<csvmode>0</csvmode>
<csvExportAncestorTypes>true</csvExportAncestorTypes>
</csvExportDefinition>
</NmLoader>
Loading that exportfile will generate 3 xml files that can be used to load in another system to make it identical.
To export a subtype of WTDocument I have tried the following:
<NmLoader>
<csvtoLocation>/ptc/Windchill/temp/export/types/MySubDocument</csvtoLocation>
<csvtoFileName>AVP_Info.xml</csvtoFileName>
<csvexportNames>wt.doc.WTDocument|com.volvo.MySubDocument</csvexportNames>
<csvExportAncestorTypes>false</csvExportAncestorTypes>
</NmLoader>
However when loading the above code, the output file (only 1 is produced) is next to empty:
<?xml version="1.0" encoding="UTF-8"?>
<NmLoader>
<csvTypeNodeIconRoot handler="com.ptc.core.lwc.server.TypeDefinitionLoader.getIconRoot">
<csviconRoot/>
</csvTypeNodeIconRoot>
</NmLoader>
Any help or insight is appreciated!
Best regards,
Peter
7-Bedrock
Jan 27, 2023 10:40 PM UTC
Did you try extracting only sub typing using its internal name? This worked for me. You could have different files generated for each sub types.
<csvexportNames>com.volvo.MySubDocument</csvexportNames>
