Apr 23, 2024 1:17 PM UTC
How to fetch custom IBA on Change Request using SQL Query?
I have a custom IBA on a change request. I need to write a SQL query to fetch all ChangeRequests which have a non-null value for that attribute.
MarcoTosin
Apr 23, 2024 2:00 PM UTC
Have you tried creating a report query builder first and then using it to generate the SQL query?
How to get the SQL statement of the Query Builder Report
Marco
HelesicPetr
Apr 24, 2024 6:38 AM UTC
Hi @Marco_Tosin
Good idea. Just create a report for ChangeRequests add a IBA attribute to the select table and then just check the resulted SQL
PetrH
