Nov 28, 2022 2:47 AM UTC
How to fetch objects linked in "change Process" tab of Chabge Request.
I want to fecth the tasks available in "Tasks for Change Process" of Change Request and link to another object available in asssociated process object of the same CR through java code.
Any help on this?
Dec 21, 2022 7:21 AM UTC
avillanueva
23-Emerald II
Nov 28, 2022 4:03 PM UTC
If you are looking to navigate to related change objects from the CR, check out ChangeHelper2 class. The table for "Tasks for Change Process" is showing you that structure and related tasks to those objects. I am not sure what you mean with the second part. Can you reply with some screenshots and context. Assuming you are not talking about customizing the "Tasks for Change Process" table, wouldn't what you asked for be achievable from adding object to the Associated Process Object table? And if its there, wouldn't it show up already?
NP_999883112-AmethystAuthorAnswer
