May 4, 2016 4:36 AM UTC
How to fetch the subtypes of Project in ProjectLink?
I have a requirement that I need to fetch all the subtypes of the Project type.
can you please let me know the available API for this?
Thanks in advance.
Best Regards,
John
May 4, 2016 8:27 PM UTC
Hi John,
Are you looking to query all the projects created using sub-type or just list all the sub-types of Project?
Bhushan
jselvaraj1-VisitorAuthor
May 5, 2016 3:46 AM UTC
Hi Bhushan,
Thanks for your reply.
I would like to list all subtypes of the project that we see from type and attributes management...
John
Aug 29, 2017 12:00 PM UTC
You can use Infoengine.
Copy the attached file in $WT_HOME/tasks.
You can test it from the browser with this URL, and you can change the type parameter
http://pdmlinkServer/Windchill/servlet/IE/tasks/TypeHierarchy.xml?type=wt.projmgmt.admin.Project
An infoengine task can be called from java.
import com.infoengine.SAK.Task
import com.infoengine.object.factory.Group
import wt.session.SessionHelper
Task task = new Task("TypeHierarchy.xml");
task.setUsername(SessionHelper.manager.getPrincipal().getName());
task.setParam("type", "wt.projmgmt.admin.Project");
task.invoke();
Group group = task.getGroup("types");
for (int i = 0; i < group.getElementCount(); i++) {
 String type = group.getAttributeValue(i,"type")
Hope it helps.
