Feb 1, 2023 5:51 AM UTC
How to find instances of EPM familytable via SQL?
How to find instances from familytable via SQL?
HelesicPetr
Feb 1, 2023 7:02 AM UTC
Hi @MN_9999219
Generally i think information is stored in a EPMSepFamilyTable
Here is example how to get filevault of familytable so if you extract the EPMSepFamilyTable you can build our select to get family instances.
 select substring(convert(varchar(100),convert(varbinary(100), FVI.uniqueSequenceNumber, 256),2),3,14) vaultFileName,apData.idA3A5 as FvItem, apData.fileName ,MSTR.documentNumber, EPM.versionIdA2versionInfo,EPM.iterationIdA2iterationInfo, MSTR.CADName from wcuser.EPMDocument EPM
inner join wcuser.EPMDocumentMaster MSTR
 on MSTR.idA2A2 = EPM.idA3masterReference
 inner join wcuser.EPMContainedIn CONTIN
 on EPM.idA2A2 = CONTIN.idA3A5
 inner join wcuser.EPMSepFamilyTable FT
 on FT.idA2A2 = CONTIN.idA3B5
 inner join wcuser.HolderToContent CONTENT
 on CONTENT.idA3A5 = FT.idA2A2
 inner join wcuser.ApplicationData apData
 ON apData.idA2A2 = CONTENT.idA3B5
 inner join wcuser.FvItem FVI
 on apData.idA3A5 = FVI.idA2A2
 where MSTR.CADName='m5x25.prt'
PetrH
HelesicPetr
Feb 1, 2023 8:30 AM UTC
ps> example is for MS SQL.
PetrH
HelesicPetr
Feb 1, 2023 9:00 AM UTC
Hi @MN_9999219
Better example for MS SQL search by CAD Model name. You can use any instance or generic cadname
select mstr.CADName,* from wcuser.EPMDocument epm
inner join wcuser.EPMDocumentMaster mstr on mstr.idA2A2=epm.idA3masterReference
inner join wcuser.EPMContainedIn contain on contain.idA3A5=epm.idA2A2
inner join wcuser.EPMSepFamilyTable sep on contain.idA3B5=sep.idA2A2
where sep.idA3masterReference in (select sep.idA3masterReference from wcuser.EPMDocument epm
where (mstr.CADName='m5x15.prt'))
 m5x15.prt is CAD fila name
PetrH
Feb 1, 2023 10:43 AM UTC
How do I get the data for entire Familytable rather than any instance or a cadname?
HelesicPetr
Feb 1, 2023 10:48 AM UTC
@MN_9999219
I don't understand your question
What kind of data?
How do you identify family table? number name filename what ever so use it.
by select you can define exactly what you want.
Use  specific column and table identification instead of "*" asterix
PetrH
MarcoTosin
Feb 1, 2023 12:49 PM UTC
HelesicPetr
Feb 1, 2023 12:56 PM UTC
Hi @Marco_Tosin
You right.
The shown sql query from the query builder is not so reader friendly but usable 😄
PetrH
