Jul 25, 2016 9:08 AM UTC
How to generate ACL report in windchill 11
for windchil 9 or 10, the following way used to give ACL report
1.Open Windchill Shell.
2.Run the following command from Windchill Shell: windchill wt.tools.support.ACLReport <output_file> where <output_file> is the file name and path where you want to export the ACL's.
3.Open the text file and search for the products whose ACL's are of concern.
Note : It dumps all the access rights on all the object and roles in the system.
However, if the same procedure is used for windchill 11, it throws error.
Can someone help in this, may be some step is missing ?
20-Turquoise
Jul 25, 2016 1:29 PM UTC
1. Open Windchill Shell.
2. Run the following command from Windchill Shell: windchill wt.tools.support.ACLReport <output_file> where <output_file> is the file name and path where you want to export the ACL's.
3. Open the text file and search for the products whose ACL's are of concern.
Works for me. Tried on both Windchill 11.0 F000-CPS05 and Windchill 11.0 M010. It would help if you posted the error(s) you are seeing.
mjha1-VisitorAuthor
Sep 8, 2016 10:08 AM UTC
Thanks for your reply and sorry for getting back so late.
I am still getting the same issue, i am attaching the error message, may be this can help
do we need to authenticate something, we were running it using the Pdmlink user.
help will be much appreciated.
2-Explorer
Sep 12, 2016 9:28 AM UTC
Try solution 2 from article below-
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS17852&art_lang=en&posno=1&q=windchill%20wt.tools.support.ACLR…
  1. In a Windchill shell, execute windu (windu.sh on Unix)
  2. Select the task Domain Policy Rule Report (DomainPolicyRule) and execute it
  3. The output file will be created under <Windchill>/WinDU/logs/<date>
