May 18, 2024 1:21 PM UTC
How to generate BOQ using rest api.
Version: Windchill 12.1
Use Case: I need to create structures for a part file where it hold the BOQ .Does windchill rest api provide support creating BOQ and How?
Description:
HelesicPetr
May 20, 2024 6:43 AM UTC
Hi @SS_10923513
Try to search the WRS documentation.- https://yourwch.com/Windchill/netmarkets/html/wrs/doc.html
PTC.ProdMgmt
[ Base URL: wch:443/Windchill/servlet/odata/v5/ProdMgmt ]
The Usage link is a link between parent and child part.
PetrH
May 18, 2024 1:34 PM UTC
Could the following article help? Article - "How to get entire BOM Structure for a given Part/Assembly along with Alternates and Substitutes for components in the structure in Windchill Rest Services": https://www.ptc.com/en/support/article/CS350014
May 18, 2024 6:20 PM UTC
Can you provide more detail in this?
Emeritus
May 27, 2024 4:38 AM UTC
Hello @SS_10923513,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution. If you found a solution yourselves, please document it in your topic and mark it as accepted solution.
Community Moderation Team.
