Nov 17, 2025 8:01 PM UTC
How to get an "Element" by ID
Version: Windchill 13.0
Use Case: The "function validateComments" script contains a "document.getElementById("workitem_comment").value" expression. I think the "workitem_comment" value is being used to represent the ID of the field for the "Comments" attribute on a workflow task object.
Description:
I am trying to find out what the element ID would be for the "Process" attribute on the same workflow task object. Please can anybody shed more light on what an element is exactly and how I can query the IDs assigned to different elements that exist in Windchill?
Jan 5, 2026 8:28 AM UTC
Use the weblink below to see information relating to Javascript elements, IDs and associated properties and methods.
https://developer.mozilla.org/en-US/docs/Web/API/Document/getElementById
Use the link found below this text to find out how browser developer tools can be used to help identify elements/IDs
Community Moderator
Dec 28, 2025 5:52 PM UTC
Hi @BF_13811900,
Thank you for your question.
Anurag
Jan 2, 2026 6:46 PM UTC
Hi. I no longer require support with this one. Please could this post be removed? It seems I am unable to remove it myself.
joe_morton
Jan 2, 2026 7:16 PM UTC
If you're able to share the solution you found, you should be able to mark that as the "Solution". That will help others in the Community in the future, in case they have the same question.
BF_1381190014-AlexandriteAuthorAnswer
