8-Gravel
Oct 2, 2025 7:19 AM UTC
How to get Gathering Part information from DB table with query sql
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.19
    joe_morton
    Oct 2, 2025 1:29 PM UTC
    hi,
    I'm not sure the specifics of querying SQL, but I can tell you that the Gathering Part attribute is on the Part Master, so you'll need to use that as a criteria in the query you build.
    Fadel
    23-Emerald II
    Oct 2, 2025 1:30 PM UTC
    SELECT hidePartInStructure, WTPartNumber, name FROM WTPartMaster ;
    Buiꓘa
