Jun 16, 2014 11:17 AM UTC
How to get global enumeration?
Hi.
How can i get global enumeration by java code?
I need all enum entries with internal and display names.
Thanks.
Feb 24, 2016 6:33 PM UTC
Did you ever have any luck with this Vasiliy Repecki‌? I think I'm trying to do the same thing... Pull out any global enumerations on the backend, either with java or via SQL.
Feb 24, 2016 7:54 PM UTC
Andrew,
Can you check if solution 133237 helps https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS133237‌
Bhushan
Mar 4, 2016 2:38 PM UTC
I think that might help! Thank you Bhushan!
