Feb 29, 2016 12:06 PM UTC
How to get list of Released objects(documents) in mail notification in promotion approval request?
Hi Gurus,
I have one customer requirement that, After approving the list of promotion objects, those object names, numbers and version should be included in a mail notification.
Kindly suggest if there is any work arounnd/customization code available for the same.
Mahesh Kumar G
2-Explorer
Feb 29, 2016 1:29 PM UTC
Declare a string workflow variable. Use the below API to get Promotion Targets. Cast the query result to respective object types, get the name and number, store it in the variable - may be append a new line after each entry. Use the variable in activity and emails
QueryResult qLatest = wt.maturity.MaturityHelper.service.getPromotionTargets(pn);
Thank you
Binesh Kumar
Medtronic - MITG
May 12, 2016 4:54 AM UTC
Hi Binesh,
Thanks for your reply, As i m beginner to customization, Could you please a sample code for The same. I am not sure how to Cast query results to Respective Documents.
Mahesh
20-Turquoise
May 13, 2016 7:34 PM UTC
Mahesh: You can do something like the following starting with Binesh's line to get the promotion request targets
while (qLatest.hasMoreElements()) {
     Object obj = qLatest.nextElement();
     String name;
     String number;
     if(obj instanceof EPMDocument) {
          EPMDocument epmDoc = (EPMDocument)obj;
          number = epmDoc.getNumber();
          name = epmDoc.getName();
     else if(obj instanceof WTPart) {
          WTPart wtPart = (WTPart)obj;
          number = wtPart.getNumber();
          name = wtPart.getName();
Randy
