May 5, 2015 11:50 AM UTC
How to Get Physical Vault File size for each iterated CAD Document in a particular lifecycle state on each Product containter
BenPerry
BenPerryAnswer
May 5, 2015 1:25 PM UTC
I think there is a command line tool that can be leveraged, but I usually prefer SQL query. The key is joining the EPMDocument table to the ApplicationData table.
Is something like this sufficient for the information you're looking for?
select
edm.cadname,
ed.versionida2versioninfo as rev,
ed.iterationida2iterationinfo as iter,
(ad.filesize/1024) as filesize_KB,
prod.namecontainerinfo as product_name
from
applicationdata ad,
holdertocontent htc,
epmdocument ed,
epmdocumentmaster edm,
pdmlinkproduct prod
where
ad.ida2a2=htc.ida3b5
and htc.ida3a5=ed.ida2a2
and ed.ida3masterreference=edm.ida2a2
and ed.ida3containerreference=prod.ida2a2
and ad.role='PRIMARY'
and ed.statestate='PRODUCTION'
order by
edm.cadname;
BenPerry
BenPerry15-MoonstoneAnswer
select
edm.cadname,
from
applicationdata ad,
epmdocument ed,
pdmlinkproduct prod
where
order by
edm.cadname;
May 6, 2015 4:30 AM UTC
Thanks a Lot.
It is exact what i expected.
I am trying the estimate size for doing Windchill Purge activity. Can you help me in getting same data except last revision.
BenPerry
May 6, 2015 12:29 PM UTC
That is where it starts to get complicated. You'll need the maximum of ed.versionsortida2versioninfo from the query above. At this point, it might be easier to put it into Query Builder. Or perhaps someone else in the community can help.
May 6, 2015 1:24 PM UTC
Dear Ben Perry ,
can you clarify, why the below 2 query output differs. I am fetching epmdocuments with INWORK Status. why Query1 and Query 2 output differs.
Query 1 :
select
count (*)
from
applicationdata ad,
epmdocument ed,
pdmlinkproduct prod
where
and ed.statestate='INWORK'
output : 238563 rows selected
Query 2 :
select count(*) From epmdocument where statestate='INWORK'
output : 449569 rows selected
BenPerry
May 6, 2015 3:07 PM UTC
There could be a number of different reasons for the difference, but we can start with this...
Query 1 is only getting EPMDocuments that are located in Product containers. You mentioned that was your original specification. Query 2 is getting EPMDocuments from everywhere - Products, Libraries, and Projects (if applicable).
May 7, 2015 3:46 AM UTC
oh. Great.
Which table hold the Library , Project list.
As i am planning to do a windchill purge for the first time, i am doing this exercise to collect how much space occupied by EPM Documents on all products, libraries & projects. And planning to purge only EPM Documents which is under ÏN-WORK State to free some space from Vault.
I noticed from your 1st query that entire vault files are located in applicationdata table and whichever file name refers CAD_NAME it linked to a epmdocument .
And other than CAD_NAME , i could see more files and space occupied by *.ol than CAD_NAME . when this .ol file getting generated, is that anyway to clear this type of files, since this .ol file type occupies by 70% of vault space.
